Random Restart during print
I was print (an object that I'd printed the, exact same file; gcode of) and then it randomly restarts
Specs:
- Printer: MK3S
- Firmware: 3.9.2-3524
- Way of Printing: SD
I haven't yet tried to reproducing issue; though something similar has happened twice, first time: bumped the LCD, and got a shock (from static), the LCD immediately was changed (the LCD was unreadable, after about 2 minutes, while printing, restarted); second time: was not printing anything at that moment, and touched the steel frame resulting in a shock (from static), LCD was again unreadable (didn't restart, after ~2 minutes, pressed the reset button)
Opublikowany : 28/12/2020 5:54 pm
