Random resets
daniel.g53
(@daniel-g53)
Random resets
Hi all,
Started this topic over in the wrong section (how do I print this) and moving it here.
https://shop.prusa3d.com/forum/how-do-i-print-this-printing-help--f63/failed-prints-and-no-fail-statistics-t27144.html
Has anyone out there experienced random resets during a print? How do I go about figuring out how to fix this? The system checks are fine, I guess the next step is looking for earthing?
Cheers
Postato : 18/01/2019 7:28 am
toaf
 toaf
(@toaf)
Re: Random resets
only time if had something close to it was I had the pi connection active AND using an sd card at the same time.
Postato : 18/01/2019 7:45 am
daniel.g53
(@daniel-g53)
Re: Random resets
Ok, I do have a pi zero installed but rpi is turned off atm. Will remove it tonight, try try again!
Cheers
Postato : 18/01/2019 7:51 am
toaf
 toaf
(@toaf)
Re: Random resets
mine went away when i just turned off the port, but who knows.
Postato : 18/01/2019 7:56 am
daniel.g53
(@daniel-g53)
Re: Random resets
#Update with a successful print... kinda
Zero W removed.
Filament sensor off
RPi off
New SD
Fresh firmware
Left the 3hr print running over night @ 50% and woke to find it complete but with the Z in home and the LCD saying heating? Bed/Nozzle stone cold but the extruder motor was 46c, it would have been sitting like that for at least 6hrs 😐
I've never seen it do this before?
Thoughts?
Cheers
Postato : 18/01/2019 10:50 pm
