radial fan unusually loud when cold
doa
 doa
(@doa)
Hi there,
are your radial fans (for print cooling, the one you can see when looking at the printer) also so extremely loud when starting the printer?
It does a fan check I assume and puts fans on 100%. My fan is making a loud sound like it's bearing is dry. It reminds me an old chipset fan on a 10-year old computer, it simply started to shake around the shaft, hence the noise
When I stop it with my finger and let it go, sometimes it stops. The fan is new, only few hours of print old. Is this normal?
thanks
Postato : 13/08/2018 8:16 am
thrawn86
(@thrawn86)
Re: radial fan unusually loud when cold
ah the death rattle of a fan. record a video, send it to support, they'll replace it.
Postato : 14/08/2018 3:30 am
doa
 doa
(@doa)
replaced, thanks
Postato : 27/08/2018 8:43 am
Steve
(@steve-3)
Mine also makes a lot of noise at startup. The noise only lasts for a few seconds. I guess it starts up at 100%, but soon reverts to a slower (quieter) speed. Maybe I should stock up on a replacement just in case.
Steve
Postato : 27/08/2018 9:31 pm
