PrusaSlicer stuck on "Exporting." when there are no extrusions of an object on the first layer
[Résolu] PrusaSlicer stuck on "Exporting." when there are no extrusions of an object on the first layer
Charonum
(@charonum)
I'm trying to print a fairly large and complex object, which caused an error when sliced: ERROR: There is an object with no extrusions in the first layer.
When I export to G-Code, It starts exporting, but never stops.
Any ideas on how to fix this?
Publié : 15/02/2022 2:13 am
You have something floating above the print-bed, you need to drop all your parts to the same bottom horizon.
If you still have difficulties save your project as a .3mf file
Files > Save Project as
Publié : 15/02/2022 3:28 am
Frank
(@frank-8)
RE: PrusaSlicer stuck on "Exporting." when there are no extrusions of an object on the first layer
I have the same problem, with a recently downloaded 'Benchy' dual-print project.  I have attached the .3mf project file as you suggested.  Any help would be appreciated.
TIA,
Frank
Publié : 19/03/2022 4:49 pm
Frank
(@frank-8)
Hmm, didn't see the attachment - I'll try again...
Publié : 19/03/2022 5:59 pm
Frank
(@frank-8)
OK, my bad.  Didn't use the 'Add Part' trick to add the second part of the '_3DBenchy_-_Dualprint_' model, so PS dropped the second part to the build plate and wouldn't let me raise it again 🙁  All good now 🙂
Publié : 19/03/2022 7:09 pm
Zoltan
(@zoltan-d-2)
Membre Moderator
Guys can you please share the secret, which slicer version do you use?
Publié : 21/03/2022 6:28 am
Frank
(@frank-8)
PS2.4.1
Publié : 21/03/2022 4:55 pm
