PrusaSlicer does not start
ZTS
 ZTS
(@zts)
Hi there,
I have used Prusa Slicer several times in the last week, it was went smoothly. Now I'm trying to start it, but it just hangs. I have found this two events in the Event viewer.
Event id 1000:
Faulting application name: prusa-slicer.exe, version: 2.3.0.0, time stamp: 0x5ffc50a6
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x0000000000000000
Faulting process id: 0x370
Faulting application start time: 0x01d70df287ef3cf5
Faulting application path: C:\Program Files\Prusa3D\PrusaSlicer\prusa-slicer.exe
Faulting module path: unknown
Report Id: b14609b5-cc95-410b-bcf0-85d939114716
Faulting package full name:
Faulting package-relative application ID:
Event ID 1001:
Fault bucket 2202464074940918562, type 5
Event Name: BEX64
Response: Not available
Cab Id: 0
Problem signature:
P1: prusa-slicer.exe
P2: 2.3.0.0
P3: 5ffc50a6
P4: StackHash_ac46
P5: 0.0.0.0
P6: 00000000
P7: PCH_95_FROM_ntdll+0x000000000009D764
P8: c0000005
P9: 0000000000000008
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA1C8.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA1F8.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA209.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA207.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA227.tmp.txt
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_prusa-slicer.exe_767a6538f7f563d7903e32fc48c1bfe7e4713_f7fb123b_eb1c00d9-1bc0-4163-8a5a-a6b8a1928a7b
Analysis symbol:
Rechecking for solution: 0
Report Status: 268435456
Hashed bucket: 6eb48141f59911022e90b9683169ab22
Cab Guid: 0
Any advice, please?
Thanks!
Opublikowany : 28/02/2021 5:17 pm
jwvaughn
(@jwvaughn)
RE: PrusaSlicer does not start
I would recommend running check disk then reinstalling the slicer. My guess is that a file or files got corrupted somehow.
jwv
Opublikowany : 01/03/2021 6:20 am
ZTS
 ZTS
(@zts)
Thanks for the reply!
I did a bit of research. Tried what you have suggested, alas it does not help. Also tried to remove all applications and windows updates that I have installed after i have used PrusaSlicer last time, again without succesd.
At last it turned out, that the Prusa Slicer it not compatible with my dual display setup.
I have a Dell XPS notebook, and a new external 4k monitor with what i have replaced my other monitor few days ago.  Usually i configure my monitors to extend the display, this was the case this time alse.
If the notebook monitor is my main display (resolution is 1920 x 1200), then the PrusaSlicer can be started.
If the external monitor is the main display (native resolution is 2560 x 1440), then the PrusaSlicer crashes.
If I have configure monitors to duplicate instead of extend, then the PrusaSlicer can be started again.
I did not experience the same behavior in any other application, so i think this must be a bug in the PrusaSlicer.
Meanwhile i found an issue on the github already for this case ( https://github.com/prusa3d/PrusaSlicer/issues/5573), so i gonna subscribe to that.
Opublikowany : 01/03/2021 10:30 am
2 ludzie polubili
Feasa
(@feasa)
@zts
This worked thank you, I have a Dell XPS and did this change and it worked first time. This is insane but it worked thanks
Opublikowany : 08/05/2021 8:18 pm
Rabbit Hole Adventures
(@rabbit-hole-adventures)
I had the same issue... I followed the advice above and it also worked for immediately...
I've spent at least 5 hours trying to figure it out. I found this thread and it took 5 seconds to fix.
Seriously, thank you VERY much!
Opublikowany : 21/01/2023 4:28 am
