Prusa Slicer with MMU2s and different nozzle sizes
tre4b
(@tre4b)
Been using this for a while and it has become somewhat of a mess.   Been trying to clean it all out and start again but can't find a reset to default for all the profile settings etc 🙁
Anyway my plan was to setup the printer and import the standard profiles and then just use them wherever possible to try to not get in a mess again.  My challenge is that when you import the profiles you get MMU and Single options for 0.25, .4 and .6 but not for .8 this only has a single.   Now I mostly only print with one filament at a time anyway and use the MMU to pick a colour or material i.e. am being lazy.
What I am not sure about is what Single does.   I assumed this was for if I needed to bypass the MMU for something like TPU.   If I use the single profile will I always have to bypass the MMU when loading as that would be an utter pain with my setup.   Up to now I had my own profile that would just work and it was fine.   I really don't see why Prusa do not just provide an MMU 0.8 preset, it can't be that hard!  I know I can create my own, but I was specifically after staying with ones that auto update etc. and will be compatible with future versions of PS.
Posted : 28/07/2022 1:44 pm
jsw
 jsw
(@jsw)
RE: Prusa Slicer with MMU2s and different nozzle sizes
The 'Single' profile is what I use when using the machine with the MMU2S installed (and turned off), but treating it as just another plain vanilla MK3S single-filament printer.
Posted : 28/07/2022 4:11 pm
tre4b
(@tre4b)
@jsw  Do you need to bypass the MMU or do you just push the filament all the way through and then just leave it loaded?
Posted : 29/07/2022 9:52 am
jsw
 jsw
(@jsw)
Posted by: @tre4b
I remove the Bowden tube between the MMU and extruder, turn off the MMU with the switch (below) and use it as more or less a plain vanilla MK3S.  Just feed the filament directly into the extruder.
Posted : 29/07/2022 12:27 pm
