Prusa ColorPrint issue
jeffrey.j2
(@jeffrey-j2)
I set up two filament changes in prusa colorprint via the web page. I set two changes; one at 1.1 and another at 1.7. It skips the 1.1 but does the 1.7. Am I missing something? I do not have mMMU. I am printing on the i3 MK3. Using Hatchbox PLA.
Any help would be appreciated.
JJ
Respondido : 17/11/2018 7:53 pm
Kai
 Kai
(@kai-2)
Re: Prusa ColorPrint issue
Hello Jeffrey,
ich have the same problems with generated gcodes from the colorprint website.
I still use it, but i check every gcode whether the m600 gcode was 1) generated and/or 2) generated at the proper hight.
I hope that helps you a bit.
Greetings
Kai
nec aspera terrent
Respondido : 19/11/2018 3:36 pm
Skyking
(@skyking)
Although I haven't purchased my Prusa printer yet, I am planning to do so soon. In the meanwhile I have been doing a lot of reading and research into the 3D printing software, products and topics including the ColorPrint function. I tried to do a simple test with ColorPrint by loading a simple model, and specifying a layer height to create the filament change and then opened the file to read it. I could not find the m600 code entry in the code, I even did a text search and it could not find the entry. Because the code generated does not produce or show the z-axis layer height for the print it is impossible for me to even see where the entry should be made. I think the code produced by the slicer software should also include the z-axis height number for reading in the code reader software or notepad etc. This would be similar to the software that I have for my cnc machine although I think this issue could become a complete other issue for a future discussion. I was planning on raising this question too so I look forward to other comments on the topic.
Respondido : 19/11/2018 7:30 pm
BillC
(@billc)
The z - height is show in the g-code as part of a move command (G0 or G1) but perhaps only once per layer so it get lost in the forest of x, y and e extrusion moves. Use something like notepad++ as your text editor and it will find a specific z height (say z0.6). I actually find it easier to put my M600 command in manually using notepad++ because I can also adjust temperature etc if required by adding additional G-code.
Bill
Tagaytay City, Philippines
Respondido : 20/11/2018 2:26 pm
Skyking
(@skyking)
Thanks for the tip. I will look into it. I was also thinking that inserting the filament change code manually may be just as easy to do.
Respondido : 21/11/2018 1:09 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
If you decide to do this, you will usually find that there is a destring prime (G1 E1 for example) immediately after where you add the M600. It's better to remove that so you don't extrude additional material after the filament change.
Peter
Respondido : 21/11/2018 1:49 pm
