Pronterface Will Not Connect
Bobby Phillips
(@bobby-phillips)
I recently upgraded my MK3 to the RC2 firmware. The printer has worked well with no issues with this firmware. However, when I load Pronterface and try to connect to the printer, the part cooling fan spins up and then stops but Pronterface doesn't indicate that a connection has been made.
I downgraded back to 3.1.3 firmware and Pronterface still will not connect. Same symptoms are present - Click <Connect>, part cooling fan spins up and then stops.
Any suggestions?
Posted : 01/05/2018 3:03 am
mooselord1
(@mooselord1)
RE: Pronterface Will Not Connect
No help to offer, but I'm running into the exact same issue with the same symptoms. Any progress since your post?
Posted : 02/08/2019 9:40 pm
Zachary Lance
(@zachary-lance)
Have you tried upgrading the firmware to 3.7.2? And if you have, double check that you have com3 selected.
You can listen to me, or not more people than me will reply to this thread
Posted : 04/08/2019 12:32 am
have you tried turning off the internal raspberry pi interface on the LCD menu's?
this stops the USB port accessing the the printer management interface.
Joan
Posted : 04/08/2019 7:14 am
mooselord1
(@mooselord1)
Joan, that worked perfectly. Thanks!
Posted : 13/08/2019 12:11 pm
