Pronterface update needed for Macbook Pro
NickAtNight
(@nickatnight)
Hello. The pronterface version that downloaded does not work with a Macbook Pro.  Apparently we need the version with the higher bit rate
Opublikowany : 09/03/2023 4:33 am
NickAtNight
(@nickatnight)
RE: Pronterface update needed for Macbook Pro
Went to Pronterface site and downloaded the latest version.
  Printrun 2.0.0rc8  kliment released this Feb 2, 2021
Opublikowany : 09/03/2023 4:35 am
NickAtNight
(@nickatnight)
Oh, I am in.  Changed Port to /dev/tty.usbmodem14101 @ 115200.  and pressed connect.
Opublikowany : 09/03/2023 4:38 am
NickAtNight
(@nickatnight)
Disconnecting Pronterface.  Started PRUSASlicer.
Downloaded new Flash
Under configuration/Flash printer firmware.
Select image:  prusa3d_fw_MK..3_12_2_5713.hex
Serial port:  Original Prusa i3 MK3 ('/dev/cu.usbmodem14101)
Press Flash !
Success.  Now on 12.2
Opublikowany : 09/03/2023 5:09 am
NickAtNight
(@nickatnight)
Oh, now we have a 12 minute Thermal model cal.
Opublikowany : 09/03/2023 5:12 am
