Problem with PLA adhering to new textured build plate
Strona 1 / 2
Dik Harrison
(@dik-harrison)
Is there a recommendation for getting better adhesion of PLA to the new textured bed?
Opublikowany : 14/04/2019 4:08 pm
vintagepc
(@vintagepc)
Re: Problem with PLA adhering to new textured build plate
Hard to say without telling us what you've already tried...
Wash with dish soap (no additives),hot water, and clean paper towel? IPA/acetone will not remove fingerprint oils, only smear them around thinly.
Opublikowany : 14/04/2019 4:20 pm
toaf
 toaf
(@toaf)
ya soap and water, maybe there is residue from the building process. I still swear PEI sweats.
Opublikowany : 14/04/2019 4:41 pm
Also, make sure your live Z is right. It will be slightly different.
Opublikowany : 14/04/2019 5:52 pm
Dik Harrison
(@dik-harrison)
Having trouble getting it to stick to do anything calibration wise, even after washing and then cleaning with acetone. Haven't been able to get a live Z print that looks like it should, it is lumpy on the left side of the build plate and smooth on the right. The rectangle at the end is ridged like it is a extrusion problem, but can't get an extrusion modifier test to stick. I have tried changing the live Z both up and down to no help. I did get my bed leveling file to print and the changes were reduced by 2-5 microns. I may just wait to tackle this build plate issue once I do the MK3S upgrade.
Opublikowany : 15/04/2019 10:41 pm
toaf
 toaf
(@toaf)
what is your live Z at now?
Opublikowany : 15/04/2019 10:52 pm
Dik Harrison
(@dik-harrison)
-.815, was -.790 before and had it at -.800 before that.
Opublikowany : 16/04/2019 4:01 pm
I was having darndest time getting PETG to stick. PLA worked fine. I found my live Z was off .300. Amazing PLA stuck to the plate.
Opublikowany : 16/04/2019 4:48 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
I use my Prusa Textured plate with PETG and do not use any bed treatment. no glue stick no hairspray nor do I use any sort of release treatment like windex For me this how I run and it has been fine for 6 kilos now of PETG
the best prep for your bed is to wash it with warm water and dawn dish soap (in the UK use Fairy liquid) by using a wad of clean kitchen paper towel dampen with warm water and put a dollop of Dawn on the pad and scrub (i do it twice at 90 deg to each other holding the plate by the edge as if it is a phonograph record, rinse under running water and dry with clean paper towel, and keep touching only by the edge... I do this every other day of printing I have not used ISO alcohol of any strength or Acetone either.
then set your live z with this method https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/life-adjust-z-my-way-t2981.html it is far better than the zig zag method in the firmware I run this with every change of filament rather than relying on old live z numbers
Opublikowany : 16/04/2019 10:08 pm
darren.p8
(@darren-p8)
I have had the same issues. i have performed all the cleaning, etc. most of my PLA prints are ok. some of the tall ones have come loose. since i can print with different materials, i now cover my print sheet with kapton tape. it works great. i only add the glue stick for NylonX.
Opublikowany : 18/04/2019 6:17 pm
Dik Harrison
(@dik-harrison)
Measured my twp build plates, the smooth is 1.0 mm, the textured 0.67 mm. Didn't realize there was such a difference. Using Jeff's method for doing live adjust of Z made a big difference in my setting with the smooth plate.
Opublikowany : 18/04/2019 8:25 pm
Fir tall prints, use a brim and or raft.
I would suspect you live z is off a little. I thought mine was right.
Now i use this: https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/life-adjust-z-my-way-t2981.html
It truely works better.
Opublikowany : 19/04/2019 11:53 am
Chocki
(@chocki)
If you have two or more build plates, you will have to get the live-z for each one then write down the difference somewhere so that you can adjust when you swap plates over.
I found getting the live-z on a smooth PEI plate is better than the textured plate, the textured plate appears to have surface thickness irregularities or bed levelling is not so accurate due to it being so thin, so once I have my settings, when I change nozzles, I get my live-z right on the thicker smooth PEI plate, then apply the offset when changing to the textured plate and PETG.
Opublikowany : 20/04/2019 11:19 am
I highly recommend you look at the above thread and get you live Z adjusted better. Nearly all, including myself, who had difficulty with adherence have found it was partially or entirely due to Live Z. PLA seems to be more forgiving of incorrect live Z settings.
Opublikowany : 20/04/2019 4:03 pm
Tjiaepbu
(@tjiaepbu)
RE: Problem with PLA adhering to new textured build plate
I hear you. I cant get anything stick to my powder coated plate.... PEI Works like a a boss, but this powder coated expensive plate does not work at all. IPA does nothing chancing height does nothing. So disappointed to these plates. Just waste of money. Wasted 2-3 kg plastic for this plate.
Opublikowany : 28/09/2019 5:07 pm
xhogan89x
(@xhogan89x)
@toaf
so i'm not the only one who says that. support looked at me like i was crazy by saying that the txt bed leaks oily stuff
Opublikowany : 29/09/2019 11:02 am
Tjiaepbu
(@tjiaepbu)
Posted by: @xhogan89x
@toaf
Ye, the print surface starts to feel oily after 1-2hours after print has started. I have tried to print large footprint prints that are only 2,2mm tall and has 600mm/2  surface area and even those wont stick. Im printing 20 at a time, and after one un-sticks hell brakes loose. And i am using prusament galaxy black filament and stock profiles etc.
This post was modified 7 years temu by Tjiaepbu
Opublikowany : 29/09/2019 12:57 pm
xhogan89x
(@xhogan89x)
@teemu-j
my PEI bed came already full of oil. even after cleaning it 5 times in a row with 96& alchool it doesn't stick. I can only print PETG successfully on this bed and as soon as the printer is done and loses the temperature, the printed obj unsticks itself from the bed very loudly and very slowly wich is creepy AF during the night.
Opublikowany : 29/09/2019 2:58 pm
Dave Avery
(@dave-avery)
will everyone with PC sheets PLEASE try washing them with plain dish soap and lots of water , using fresh paper towels  and then drying with more fresh paper towels followed by a heated dry on the heated bed.
99%IPA ( puddled on the sheet ) is fine for touch ups but not for heavy cleaning
Opublikowany : 29/09/2019 9:08 pm
Hmmm... I have three Printers running Powder coated prusa build plates and they all print PLA
they are from different batches...
this my Mk2 and a bit... with MMU1 part way through a 4 colour print!
the printer is a mk2 with 12volt mk52 magnetic heatbed and powder coated buildplate!
Joan
Opublikowany : 29/09/2019 10:58 pm
Strona 1 / 2
