Problem with layer above infill
Hi everyone,
I am printing a part with the standard 15% infill sliced in Prusa Slicer 2.4.2, Prusament PLA.
In the layer above the infill, i get gaps on the outer border, picture attached. I am kind of at a loss on were to start looking for the problem and would appreciate any input.
Napsal : 21/05/2022 8:48 am
RE: Problem with layer above infill
15% is a bit on the low side, in my opinion. I'd try 20%. There's also a setting to adjust the infill perimeter overlap that you may want to check out. On the road right now so can't look up the actual name for this setting.
Napsal : 21/05/2022 3:34 pm
@jurgen-2
it's not a problem.
This is normal, its the bridging layer, 15% infill is fine, let the print finish.
Enjoy
Swiss_Cheese
The Filament Whisperer
Napsal : 21/05/2022 3:49 pm
