Printshee doesn´t fully stick to heatbed
kaouch2000
(@kaouch2000)
Hi guys, I´m already prusaprinting for years without any big troubles. But now there is one problem I can´t get solved.
When I place the printsheet, no matter which one, on the heatbed it is flat on it, after heating up the heatbed the printsheets bending in the center.
First thought was maybe a magnet had fallen off in the middle. BINGO! Reglued the one which felt of in the center. But no change. Still bulging in the center :/
Any idea? 😀
Probably it´s an idiotic mistake of mine.
Ce sujet a été modifié il y a 3 years par kaouch2000
Publié : 01/12/2022 7:56 am
kaouch2000
(@kaouch2000)
RE: Printshee doesn´t fully stick to heatbed
Or is there a need to renew all the magnets from time to time? I read stuff about, that neodym-magnets could become weak because of heat. But I assume Prusa probably (hopefully) will have special ones for the heatbed.
Publié : 01/12/2022 8:36 am
Pictures?
Your print bed doesn't get anywhere near hot enough to derange the magnets.
Publié : 01/12/2022 10:28 am
kaouch2000
(@kaouch2000)
Hi there, thx for replying,
I´ll post a video as soon as possible (unfortunately tomorrow), you won´t see it on a picture. But maybe I can explain the problem a bit better:
When the heatbed is cold the PEI-Sheet or the structured sheet are laying flat on the bed. When the bed heats up, the printsheet starts to bend in the center. There is a little hill in the center which you could press down to the bed. That´ s why the z-calibriation is going to fail when the extruder reaches the center.
Sorry to be not at home till tomorrow to post you a video instantly.
Thx  Andrew
Publié : 01/12/2022 10:43 am
kaouch2000
(@kaouch2000)
Publié : 01/12/2022 10:45 am
Er, I should have been clearer.  I was hoping to see some indication of the degree of bending - say a straightedge laid on the sheet...
Publié : 01/12/2022 12:11 pm
kaouch2000
(@kaouch2000)
IMG_0397
I hope you can work with that 😀
Ce message a été modifié il y a 3 years par kaouch2000
Publié : 01/12/2022 6:31 pm
Thomas Lynch
(@thomas-lynch)
Does the heatbed do this without a print sheet on it when it is heated up?
Publié : 01/12/2022 10:15 pm
kaouch2000
(@kaouch2000)
No, the heatbed itself stays flat. Also when I take off the hot printsheet from the heatbed it remains bended, as long as it cools down. While being hot you can easily bend/push it from one side to the other and it will make a noise like a click frog, if you know what I mean. Could it be, that the sheet gets to hot in the center. No matter what printsheet I use.
Publié : 01/12/2022 11:13 pm
kaouch2000
(@kaouch2000)
But maybe this „clickfrogging“ is a normal behaviour, I didn‘t care in the past. Usually I leave the sheet on the printer as long as it is warm.
Publié : 01/12/2022 11:32 pm
kaouch2000
(@kaouch2000)
Latest: I reglued all loose magnets, no change so far. The sheet starts to warp at 80 degrees bed temperature. The bed is very hot in the middle, at the edges only warm.
I have a cut copper-strip (picture below) at the surface of the bed which is there for almost half a year and didn´t make any troubles so far. Could that suddenly cause the heatbed to only warm up in the middle? Is there a possibility to easily repair/sold the strip or to I have to order a new bed
Ce message a été modifié il y a 3 years 3 fois par kaouch2000
Publié : 02/12/2022 8:13 am
kaouch2000
(@kaouch2000)
Problem solved: After soldering the copper trace and finished with nail polish the bed heats up evenly and the sheet doesn´t bend anymore.
Maybe someone has the same problem, so here is the solution 😀
Thank you all for your help!
Publié : 02/12/2022 10:46 pm
