Printing with PET keeps pausing
Alex B
(@alex-b)
I am trying to print a few things with my MK3 and the newest firmware and PET. Every time I print it just prints a bit and then pauses.
I have tried a few models and they all do the same thing. I have also tried S3D and PrusaControl... Same thing.
Here is what I see in OctoPrint, any ideas??
Send: N17 G1 X100.0 E12.5 F1000.0*109
Recv: ok
Send: N18 G92 E0.0*96
Recv: ok
Send: N19 M900 K30*122
Recv: Unknown M code: $19 M900 K30
Recv: ok
Send: N20 M105*21
Recv: ok T:240.5 /240.0 B:90.1 /90.0 T0:240.5 /240.0 @:33 B@:83 P:24.1 A:29.4
Send: N21 G1 E-0.8000 F2100*32
Recv: ok
Send: N22 G1 Z0.750 F12000*27
Recv: ok
Send: N23 T0*11
Recv: echo:busy: processing
Recv: echo:Active Extruder: 0
Recv: ok
Recv: echo:Enqueing to the front: "G1 E-3 F200"
Send: N24 M105*17
Recv: echo:Enqueing to the front: "G1 E3 F200"
Recv: echo:Enqueing to the front: "M600"
Recv: echo:busy: paused for user
Thanks!
Veröffentlicht : 14/04/2018 2:20 pm
Alex B
(@alex-b)
Re: Printing with PET keeps pausing
Interesting, the same G code works with ABS, I have no idea, I am printing at 240 which is Ok for either material...
Any ideas?
Veröffentlicht : 14/04/2018 3:39 pm
Peter L
(@peter-l)
Any ideas?
Your filament sensor is falesely detecting that your filament jammed. Turn off the filament sensor.
The optical sensor has problems with some filaments, and PETG seems to be a common problem.
Veröffentlicht : 15/04/2018 10:19 pm
motocoder
(@motocoder)
Any ideas?
I can confirm this. I had the exact same problem with transparent orange PETG, and turning the filament sensor off solved the issue.
Veröffentlicht : 16/04/2018 4:01 am
nuroo
(@nuroo)
+1
Inland Translucent Orange PETG
Inland Translucent Magenta PETG
Lots false jams detected. Disabled filament sensor when printing these materials. Firmware 3.2.0rc1
Prusa MK3 > MK4s
Prusa MK2.5 kit > MK3 > MK3s > MK4s
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6 - taken apart for space
CR10s4 - upgrading
Delta 3ku - dont use
Veröffentlicht : 19/04/2018 12:30 am
Martin Stoufer
(@martin-stoufer)
So are all these false errors due to the translucency of the PETG material causing the filament sensor to get a false read? If one could gently abrade the surface of the filament to give it more of an opaque surface, would that address the situation?
Veröffentlicht : 19/04/2018 6:34 am
Chris
(@chris-16)
just turning the sensor off is enough. especially since the sensor does not do much more than check for runouts. I have never had it once even catch a stuck filament. so other than loading and catching when you run out of filament there isn't much use for it now.
yes to translucency, if it gets enough light through the filament it assumes it is out. Glossy black pet-g/abs/pla can also fool it.
Veröffentlicht : 19/04/2018 8:15 am
