Printer stuck with dark LCD after Firmware Upgrade
UB_Glade
(@ub_glade)
Hi together,
till now the Printer works without any Trouble. (OK OK, I know, never change a running System 🙄
I just try to upgrade the FW from 3.9.3 to 3.10.0, all works fine but after the writeout "verifying ...100%" the LCD gets Black (lights out) and no Restart occours. 😱
After a Reset the Priter starts, the LCD gets dark with "Original Prusa i3 Prusa Research ..." then the LCD Light flashes one Time and thats it.
I try do downgrade to 3.9.3 and 3.9.2 successfull but with all FW the same issue.
Is this a known issue?
What can I do?
Uwe Prusa i3 MK3S Kit, MMU2s
... Über 90% aller Fehler sitzen vor dem Bildschirm, fragt sich nur vor welchem. 🙂
... Over 90% of all errors are in front of the screen, the only question…
Opublikowany : 26/05/2021 3:32 pm
RE: Printer stuck with dark LCD after Firmware Upgrade
I have never seen this one.  I would post an issue on GitHub.
Opublikowany : 26/05/2021 7:13 pm
UB_Glade
(@ub_glade)
Hi Chuck,
Iwill do
Opublikowany : 26/05/2021 10:05 pm
