printer stopt and start randomly with usb
Gabasky
(@gabasky)
printer stop randomly for few secund and print after that like nothing hapend. i use usb prontoface and old laptop.
Napsal : 29/06/2022 3:22 pm
RandyM9
(@randym9)
RE: printer stopt and start randomly with usb
Better to use the SD card to reduce the chance of errors.
If the laptop goes into a sleep or idle mode your prints will be interrupted.
To eliminate the SD card shuffle, consider getting a raspberry pi and installing octoprint.
Cheers
Napsal : 30/06/2022 4:32 am
Chocki
(@chocki)
Printing through USB is not recommended as it is prone to stops and starts as the USB goes to sleep on the PC, and or another process has a higher priority than the printer software so takes control of the PC causing USB data to be interrupted.
You are better off using an SD card or Octoprint running on a dedicated Raspberry Pi.
Napsal : 07/07/2022 5:15 pm
1 lidem se líbí
