Printer software related overextrusion
Marcin Rojek
(@marcin-rojek)
Hello,
At the beginning I would like to point out that I use Prusa filaments with appropriately adjusted print parameters.
The problem I encountered is the excessive extrusion that seems to be related to the extruder motor driver software.
This is manifested by a characteristic click when calibrating the first layer, or filament change when the motor tries to push out too much filament at once.
I am able to eliminate the problem in the printouts by setting the extusion multiplier to 0.4, which is an absurdly low value, even if I used the worst quality filaments.
Is there any method to calibrate the extruder motor? As long as it does not bother me in printing, I would prefer to work with a fully functional machine. For example, due to difficulties in calibration, filament replacement and all other operations that I cannot correct in G-CODE.
I will be grateful for any help
Respondido : 02/05/2022 9:32 am
