Printer restarts during printing when using PrusaSlicer 2.2.0
Dieter
(@dieter-2)
Hello,
does anyone else have such a problem?
Printing on MK3S, 3.9.2 from SD card, GCode creation with PrusaSlicer 2.2.0 - win64
During printing, the printer makes a restart. The restart is not random, it always occurs at the same point while printing the object.
Nearly every object I sliced with PrusaSclicer 2.2.0 have this problem (but, when I added Raft to the Print, it prints without restart). Also with firmware 3.9.0
Slicing the same objects with PrusaSclicer 2.1.1, it prints without any problem.
Interesting, when sclicing with 2.2.  Gcode size about 11 MByte, print time should be 6h39
Slicing with 2.1.1 (same object):    Gcode size 14 MByte, print time should be 7h37
I added a bug: https://github.com/prusa3d/Prusa-Firmware/issues/2918
Dieses Thema wurde geändert Vor 5 years von Dieter
Veröffentlicht : 19/12/2020 1:49 pm
Dieter
(@dieter-2)
RE: Printer restarts during printing when using PrusaSlicer 2.2.0
Slicer-2.2.0-P30_Wheel_Default_0.15mm_PLA_MK3S_6h39m.gcode
Slicer-2.1.1-P30_Wheel_Default_0.15mm_PLA_MK3S_7h37m.gcode
Veröffentlicht : 19/12/2020 2:18 pm
Dieter
(@dieter-2)
Even the printer restarted always at the same position (so I don't think that is was a random restart) it is gone now (with the same gcode files). So I will close the bug for now.
Veröffentlicht : 26/12/2020 6:44 pm
You never opened a bug.  This is a user to user forum.  If you want to raise an actual bug you need to create an issue on the github tracker for Prusa Slicer at https://github.com/prusa3d/PrusaSlicer/issues
Veröffentlicht : 26/12/2020 9:55 pm
Dieter
(@dieter-2)
@neophyl
I opened it in the Firmware repository, as the printer never ever should do a restart during a print. . https://github.com/prusa3d/Prusa-Firmware/issues/2918
But I closed it yesterday, as I cannot reproduce it anymore.
Diese r Beitrag wurde geändert Vor 5 years von Dieter
Veröffentlicht : 27/12/2020 9:23 am
