printer randomly stutters during print
mlmarklamb142
(@mlmarklamb142)
Since the latest firmware release (fw_3_7_2_mk3s) the printer will occasionally start stuttering like the processor can't keep up with the program. Usually stutters for 1 to 1 1/2 minutes then clears up and starts printing like it's supposed to. Sometimes it will do this multiple times during a single print. Today, on a 20 minute print, it happened twice. The attached video shows it stuttering, then clearing up. Any ideas as to what's happening ?
Questa discussione è stata modificata 7 years fa da mlmarklamb142
Postato : 28/07/2019 2:04 pm
mlmarklamb142
(@mlmarklamb142)
RE: printer randomly stutters during print
Is there a problem with uploading videos, or am I missing something ???
Postato : 28/07/2019 11:55 pm
Dave Avery
(@dave-avery)
drag  and drop the video into the edit box and the set the media link in the popup
Postato : 29/07/2019 12:01 am
mlmarklamb142
(@mlmarklamb142)
20190728_093011
Thanks david-a66
Postato : 29/07/2019 12:20 am
Are you printing from the SD card or via USB?
Postato : 29/07/2019 8:06 am
mlmarklamb142
(@mlmarklamb142)
I was printing from usb. Most of my prints are from usb, but it never happened until after the firmware update. Could be just a coincidence.
Next few prints I'll try running from the sd.
Postato : 30/07/2019 9:27 pm
mlmarklamb142
(@mlmarklamb142)
Ran a print from the sd-card today, a little over 2 hrs. No stuttering at all. I'll try a few using the sd, then run a few more from the usb and see what happens.
Nobody else has had this problem ???
Postato : 01/08/2019 5:26 pm
rmm200
(@rmm200)
Only ones I have heard of are using Pi Zero. What do you have plugged into your USB?
Postato : 01/08/2019 5:42 pm
Nikolai
(@nikolai)
Posted by: mlmarklamb142
None I've seen so far on github. If it's  happening only with usb connection, then it's most likely the PC/Raspi you're using causing this issue.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Postato : 01/08/2019 5:45 pm
There have certainly been reports of USB printing causing problems. After spending many posts trying to assist someone with similar problems only to find that they'd neglected to mention they were printing over USB, I've added it to my list of extruder click troubleshooting questions. The obvious question is what's on the other end. The Raspberry Pi Zero is hard put to do both USB and wifi concurrently, for example.
I'd only experienced a layer shift once in 18 months of owning my Prusa and printing exclusively via SD. Since connecting via USB, I've had it happen a half dozen times in the last month. (Moral: Don't load up the CPU during timing-sensitve prints.)
Always simplify when troubleshooting.
Postato : 01/08/2019 6:18 pm
Microsoft Windows is NOT an RTOS.  Nor are most Linux builds. Garbage collection can do all sorts of weird things to communications that require software polling.
Postato : 02/08/2019 3:11 am
mlmarklamb142
(@mlmarklamb142)
Not running a raspberry and the only things plugged into usb is the printer, external hard drive and the wireless gizmo for logitech keyboard and mouse.
Postato : 02/08/2019 3:28 pm
So yes, you are printing via USB. Try printing the same gcode directly off the SD card and see if there's an improvement. If so, you've got your answer. If not, update the info you've posted. That's the best troubleshooting process at this point.
(A USB hard drive can push the USB bus pretty hard, especially if you've got crappy drivers that use a lot of CPU power. USB2 or 3 may make a difference as well.)
Postato : 02/08/2019 4:15 pm
For an abundance of clarity: what folk are asking is for you to remove the USB cable from the printer, insert the SD card into the printer, select the file to print.  The only thing connected to the printer should be the power cord.
Postato : 02/08/2019 6:54 pm
