Printer not accepting filament
SWAG_4_1if3
(@swag_4_1if3)
I was doing a print that required multiple filament changes, which I have done before with no problem.  The filament was ejected, I went to insert the new color, and it won't feed in.  I can see that the filament gear is turning to accept the filament, but it won't go into the hot end.  It's almost like it's blocked.  I've heated the hot end and inserted a needle in case there is some blockage but no matter what I have tried, the filament won't feed into the hotend.
Any ideas on how to fix this?  I can't do a cold pull because I can't even get the filament into the hot end to do one so I'm at a loss as to how to get it working again.
Best Answer by alex:
Hi there,
Sounds like you have a ptfe tubing problem i would try this.
https://help.prusa3d.com/guide/how-to-replace-a-hotend-ptfe-tube-mk3s-mk3s-mk2-5s-mmu2s_21664
Veröffentlicht : 05/12/2022 3:45 pm
alex
 alex
(@alex-28)
RE: Printer not accepting filament
Hi there,
Veröffentlicht : 10/12/2022 12:54 am
alex
 alex
(@alex-28)
Did this work
Veröffentlicht : 14/12/2022 3:24 am
SWAG_4_1if3
(@swag_4_1if3)
I'll let you know as soon as I get some PTFE tubing
Veröffentlicht : 14/12/2022 8:45 pm
Hello
(@hello)
Just to let you know that you get ptfe tubing in the spres bag if you got kit
Veröffentlicht : 15/12/2022 3:11 am
SWAG_4_1if3
(@swag_4_1if3)
Yep...I do believe this was this issue.  Took a while for me to get the hot end out in order to pull the tube but based on what you see here, I suspect this is what was causing the block.
Thanks for the help!  Was beginning to think I wasn't going to be able to print ever again.
Veröffentlicht : 18/12/2022 5:30 pm
SWAG_4_1if3
(@swag_4_1if3)
I can confirm that after changing the tube the printer is once again accepting filament.  Just recalibrated and everything seems good to go.
Much appreciated!!!
Veröffentlicht : 18/12/2022 6:04 pm
