Printer firmware crashes on unload filament and geared extruder
Andreas
(@andreas-12)
Hi there!
Since the last two firmware updates (actual 3.8.1) my extruder motor makes an loud sqeeking noise when I try to eject the filament using the menu. After 2 seconds sqeeking it shows me a message that "static memory has been overwritten".
I have an Zesty Nimble extruder installed which has an 30:1 gear ratio. Thats why I'm using it at 1/8 microstepping and 1338 e-steps per unit.
Any ideas how to fix this without digging into the sources?
-> Thanks in advance!
Napsal : 27/10/2019 6:52 pm
