Printbed indicates 90-100 without preheating
Tmckie
(@tmckie)
On the info screen on startup - nozzle temp is 21, printbed indicated 90-100 without any preheating.  The printbed is cool to the touch.  New preassembled printer - what do I need to check?
Best Answer by Neophyl:
Check your wiring for the bed temperature sensor.  If the wirings ok then check the sensor itself.
This page might be of use to you https://help.prusa3d.com/en/article/multimeter-usage_2117/
Posted : 04/06/2021 5:01 pm
RE: Printbed indicates 90-100 without preheating
Posted : 04/06/2021 6:57 pm
It may just be a plug shaken loose in transit.  The first check is to make sure they are all pushed home.
Posted : 04/06/2021 7:40 pm
Tmckie
(@tmckie)
@neophyl
Good tip! I ended up switching thermistor with hotend and then had the high reading at hotend. Prusa accepted this as bad thermistor and is resending the part.
Posted : 05/06/2021 3:05 am
