print stepover?
Drazi
(@drazi)
print stepover?
in the machining world, it is the radial cutter engagement ....
what is the setting for this in Prusa Slicer? is it controllable?
bla bla bla
Opublikowany : 24/05/2023 4:23 am
Robin_13
(@robin_13)
RE: print stepover?
Without being a machinist, what are you asking for?  If I read it correctly, Radial Cutter Engagement is changing the tool speed as you make finer cuts.
Opublikowany : 04/06/2023 6:08 pm
