Print sequence/order in Prusa Slicer
wieman01
(@wieman01)
Hello,
I am not sure if that feature exists or not, my online research did not reveal much.
Can you change/determine the print sequence of (multiple) objects using Prusa Slicer or does the software decided which objects to print first?
I may be missing that feature, and as far as I understand the non-Prusa fork (3D Slicer) lets you do that.
3D Druck für Einsteiger leicht gemacht: www.3d-druck-lernen.de
Napsal : 03/10/2019 4:31 pm
RE: Print sequence/order in Prusa Slicer
https://forum.prusa3d.com/forum/prusaslicer/order-of-printing-multiple-items/   try looking in the Prusa Slicer forum located towards the bottom of the lists
Napsal : 03/10/2019 6:32 pm
wieman01 se líbí
wieman01
(@wieman01)
Thank you, Neophyl, that worked perfectly. I just changed the order in which I loaded the models and I got the sequence right this time.
Napsal : 03/10/2019 8:28 pm
