Print quality problem
Here is a print from my Prusa Mini on the left and rom my Mk3 on the right. Both were sliced with Prusa Slicer and the same settings for both and both machines have a .25 nozzle. Could the rough print from the Mk3 be caused by the nozzle pressure? and if so how do I adjust the pressure? What do you think I should do to make a better print that is closer to the Mini's version?
Thanks for the help!
Publié : 13/03/2021 7:04 pm
RE: Print quality problem
If by nozzle pressure you mean how low the nozzle is, this is the adjust to run.
Looks like they could be a tad low.
Tank you very much!
Publié : 14/03/2021 10:48 pm
