Print head temperature reading not increasing
kenjustken42
(@kenjustken42)
When starting a new print I am the print head temperature is not reading the correct value.  It barely increases when I start the heating process.  I put an IR Thermometer on the head and I can see it increasing just fine and reading over 80 but the panel says 39.  I had this problem last night and I re-seated some of the cables and it starting working.  This morning I re-seated the thermistor cable again and it did not fix it.  What should I do to trouble shoot this.  I have my own DVM and other test equipment here.
Postato : 13/04/2020 5:25 pm
kenjustken42
(@kenjustken42)
RE: Print head temperature reading not increasing
I found my issue.  The thermistor had somehow been pulled off the board.  Once I fixed that and put it back, problem was solved.  Since the cable had been pulled through to the wiring harness, it had to have happened during construction.
Postato : 13/04/2020 10:01 pm
