Print fan alternative discussion
Chocki
(@chocki)
What are your thoughts on using a Noctua Radial fan instead of the 5015 blower currently fitted to the Prusa i3 Mk3.
https://noctua.at/en/products/fan/nf-a4x20-5v
A suitable adapter would have to be made to convert the fan intake, but personally I don't like the supplied fan, it's noisy and rattly and near enough impossible to source except from PRUSA and I don't think it will last long (Going by mine, which rattles like anything!).
I know the radial type fans are supposed to provide higher CFM, but in this application, would it really make that much difference?.
The problem is I can find no technical data on the PRUSA print fan as in CFM Static Pressure etc.
Publié : 25/02/2019 1:09 pm
Chocki
(@chocki)
Re: Print fan alternative discussion
Sorry wrong link in the above, I put the one for the 12v version - Doh!
Correct link:
Publié : 25/02/2019 1:14 pm
