Re: Power supply noise
Hi
I also have a vibration noise from the power supply which is due to a rattling heat sink half way up the PSU board. The noise can be made by tapping on the heat bed on the back right.
Not wanting to disassemble the unit at this point I am making a plastic clip that will locate onto the cover grill and gently put pressure onto the heat sink.
Publié : 08/09/2018 12:05 pm
Mine does it to when not under any load i.e. when sat idle
Publié : 08/09/2018 12:17 pm
RE: Power supply noise
Mine just started making a noise today - any word on this Prusa? Thank you
Publié : 06/05/2020 10:06 pm
