Power supply noise
berthold.h
(@berthold-h)
Power supply noise
I am getting a lot of rattling vibration noise from my power supply. It is clearly coming from inside the PSU. I attach video (zipped) to illustrate.
Is there any way to get rid of that? I believe this is a known issue.
Regards
Berthold
Respondido : 30/07/2018 2:56 pm
suremicro
(@suremicro)
Re: Power supply noise
Hi
I also have a vibration noise from the power supply which is due to a rattling heat sink half way up the PSU board. The noise can be made by tapping on the heat bed on the back right.
Not wanting to disassemble the unit at this point I am making a plastic clip that will locate onto the cover grill and gently put pressure onto the heat sink.
Respondido : 08/09/2018 12:05 pm
Robin
(@robin-4)
Mine does it to when not under any load i.e. when sat idle
Respondido : 08/09/2018 12:17 pm
tmixer
(@tmixer)
RE: Power supply noise
Mine just started making a noise today - any word on this Prusa?  Thank you
Respondido : 06/05/2020 10:06 pm
