Power Supply just died
JasonG
(@jasong)
Anyone have their power supply fail on them?  The case got hot and the fuse blew.  I replaced with another fuse and it blew that one as well.  My printer had been running great for a long time.  Today I just tried printing PETG, and was running bed at 85 deg and hot end at 255.  I never ran it this hot before, but the printer should be able to handle this no problem.
Super frustrating, I cant even find a good way to contact prusa for support.
Veröffentlicht : 21/09/2019 7:09 pm
Mitglied
RE: Power Supply just died
Yes and had is replaced after a chat with the store.
Veröffentlicht : 21/09/2019 7:12 pm
JasonG
(@jasong)
so do I have a bad supply, or was I overloading it?  I wouldnt think that running it that hard should cause this issue.
Veröffentlicht : 21/09/2019 7:19 pm
JasonG
(@jasong)
Prusa support is sending me a new supply.  Hopefully the one I had was just bad, and I never pushed it just printing PLA.  As soon as I started with PETG, using much higher temps, it failed.  It didnt fail catastrophically thank god, it just popped.  Replacement fuses pop too.  Maybe in a few weeks I will get the replacement from prusa.
Veröffentlicht : 22/09/2019 12:25 am
rmm200
(@rmm200)
Mean Well makes a dandy 350 watt PSU to tide you over until the replacement arrives.
It is about $33 on Amazon.
https://smile.amazon.com/dp/B077B36KPB/ref=dp_cerb_3
And check the comments...
Veröffentlicht : 22/09/2019 1:11 am
JasonG
(@jasong)
Yes I actually bought one.  I will move it to my FT-5 once I get the replacement.  My FT-5 has 120vac heated bed so its draw will be nothing.
Thanks
Veröffentlicht : 22/09/2019 5:08 am
Mitglied
I have one with the old style and I am replacing it.  I like the replaceable power panic cable.
Veröffentlicht : 22/09/2019 4:22 pm
rmm200
(@rmm200)
I wish there were a way to add Power Panic to the Mean Well. Someone needs to sell an adapter board...
Diese r Beitrag wurde geändert Vor 7 years von rmm200
Veröffentlicht : 22/09/2019 5:56 pm
Mitglied
Posted by: @jason-g24
What is an FT-5"
Thanks
Veröffentlicht : 22/09/2019 7:25 pm
Bunny Science
(@bunny-science)
https://www.amazon.com/Voltage-Switch-Supply-Detection-Module/dp/B07T2ZRS4Q
https://www.amazon.com/Zamtac-Voltage-Switch-Wiring-Harness/dp/B07QFMB537
https://www.amazon.com/3D-Printer-printer-Voltage-Socket/dp/B07L1RYS73
Ironically, I have my original power panic boards installed, but don't use power panic. On one machine, I didn't even bother hooking it back up. A UPS takes care of brief power fails and generator power is only 30 seconds away.
Diese r Beitrag wurde geändert Vor 7 years von Bunny Science
Veröffentlicht : 22/09/2019 8:13 pm
rmm200
(@rmm200)
Thant you!
Well there goes my excuse for not swapping in the Mean Well...
Veröffentlicht : 22/09/2019 9:21 pm
JasonG
(@jasong)
@charles-h13
FT-5 is a folgertech larger format printer, does 300x300x400mm.. its a beast and requires a lot of tweaking unlike the prusa, that just works all the time.
Veröffentlicht : 22/09/2019 10:56 pm
