Power issues with printer - need help
mephisto
(@mephisto)
hi everyone,
so i borrowed a Prusa i3 mk3 from my brother the other day.
today i wanted to power it on for the first time, but there is nothing happening. so i broke out the multimeter and now i am a bit confused.
here you can see that i do not have power across the main power input terminals on the PSU
https://imgur.com/a/FaaBFyU
but when i disconnect the L wire from the power panic board test then i see voltage
https://imgur.com/a/XSxCt9R
for the test i disconnected the rocker switch.
has anybody got an idea what could be the problem here?
thank you for your help
Opublikowany : 20/09/2021 7:05 am
Support
I would definitely contact support.  You may have a bad PSU.
Opublikowany : 20/09/2021 8:56 am
mephisto
(@mephisto)
RE: Power issues with printer - need help
i did fear that might be the case.
also i just checked, i do not have the Chat option when i open the site - even with multiple browser, not sure why this is happening
edit: found the chat, it is just in the shop
Opublikowany : 20/09/2021 9:19 am
mephisto
(@mephisto)
power panic board
with the help of support  i was able to narrow the issue down to the power panic  board.
unfortunately there are no spare  parts for it.
does someone know, if i could just skip the board? what does it actually do?
Opublikowany : 20/09/2021 11:04 am
Login
You have to login.  You will need to use your brother's account/
Opublikowany : 20/09/2021 11:25 am
the power panic board, monitors the incoming power for problems, and triggers a self protection action in the printer to try and save the current position data before power failure, in the hopes that the printer can resume printing when power is restored.
unfortunately it is not fool proof...
I use a UPS in preference...
you could bypass the power panic board and have a working printer without power panic, quite quickly!
Power panic boards are available on Aliexpress.
I have no idea how good they are
https://www.aliexpress.com/item/32907416054.html?spm=a2g0o.productlist.0.0.4740651bB4pliY&algo_pvid=3d7a6b88-470c-409f-a49f-636604d7f86d&algo_exp_id=3d7a6b88-470c-409f-a49f-636604d7f86d-0&pdp_ext_f=%7B%22sku_id%22%3A%2210000006256994113%22%7D
Opublikowany : 20/09/2021 4:32 pm
mephisto
(@mephisto)
power panic
thank you for your response.
i did just dad a moment ago, and now i am calibrating the machine.
Opublikowany : 20/09/2021 4:45 pm
Best wishes
Joan
Opublikowany : 20/09/2021 5:25 pm
Good news
Happy printing!
Opublikowany : 20/09/2021 6:06 pm
