Possible Thermistor Short/Fried?
john.o25
(@john-o25)
A few days ago I had an ABS print fail badly and the hotend got all gunked up with ABS blobs.  I headed the tool and then used some needle nose pliers to pull the majority of the ABS off the block.  Sadly I wasn't as careful as I should have been, and when I was trying to get some off my pliers hit the thermistor cartridge and there were some pretty good sparks.
Since then I have been trying to print in ABS and PLA.  Both are failing miserably.  PLA is having major issues with layer adhesion.  The prints are brittle and the layers separate when I am pulling the part from the bed.  I am also seeing major issues with the first layer.  See the picture for what I mean.
I have tried using Live Z Adjust to no avail.  I have been trying every setting in Slic3r for the last two days and I am pulling my hair out.  I can't get a quality print to save my life.  Any suggestions would be greatly appreciated.
Posted : 27/10/2019 9:22 pm
RE: Possible Thermistor Short/Fried?
The sparks were probably the heater cartridge leads.  But the only way to tell if things were damaged is to grab a DMM and start measuring resistances and voltages.  It could be mechanical and you are fighting a bent heat break.
Posted : 28/10/2019 7:45 am
