PlA clog in Heatbreak prevention
Joseph
(@joseph-3)
I recently managed to pull out a stick of filament jammed in the heatbreak. I posted about this problem in here Pip Spring Box but didn't get a reply. How do I prevent this from happening again? Am using Prusa MK3S with its heatbreak.
Opublikowany : 27/12/2020 8:26 am
RE: PlA clog in Heatbreak prevention
what retraction settings are you using?
I use 0.4mm for PLA and PETG
Opublikowany : 27/12/2020 11:46 am
Joseph
(@joseph-3)
 Retraction settings     nvr touched it, PrusaSlc3r default setting
Opublikowany : 27/12/2020 12:30 pm
can you save a copy of the Project file for the model  (.3MF)  (You will have to zip the file, in order to be able to post it) from Prusa Slicer, and attach it to your next post?
Opublikowany : 27/12/2020 1:00 pm
Joseph
(@joseph-3)
here it is https://we.tl/t-b7yKh3q8VL
This post was modified 5 years temu 2 times by Joseph
Opublikowany : 27/12/2020 3:44 pm
Hi Joseph, are you using Prusament  PLA?
Opublikowany : 27/12/2020 7:27 pm
Joseph
(@joseph-3)
Not using Prusament PLA, but PLA from Happyrcpalace https://www.happyrcpalace.com/product-category/3d-printer-filament/
Opublikowany : 28/12/2020 2:02 am
