PINDA not recognizing bed
TreeTolber
(@treetolber)
So after I assembled the printer and began the wizard, during the Z calibration the PINDA fails to stop before pushing the bed down about 3 or 4 mm, then get an error that it failed to detect the bed.
Postato : 19/09/2022 6:27 am
Lichtjaeger
(@lichtjaeger)
RE: PINDA not recognizing bed
First, check if the PINDA works. The indicator LED should switch if you touch the head with a screwdriver (or any other metal object). To check the connection to the board, you can navigate in the printer menu to "Support -> Sensor Info" and test again.
If it is connected correctly it might be the installation height. The PINDA should be about 1-1.5mm higher than the nozzle. See the guide.
Postato : 19/09/2022 7:34 am
TreeTolber
(@treetolber)
Thanks for the info.  I will check that out later today.
Postato : 19/09/2022 7:41 pm
TreeTolber
(@treetolber)
After replacing the PINDA device it was determined that the main control board was faulty so Prusa sent out a new one.
Postato : 11/10/2022 7:26 am
has the replacement Einsy arrived yet?
Postato : 11/10/2022 8:15 am
TreeTolber
(@treetolber)
Yes it did arrive within a few days. I installed it, reassembled the printer and everything is perfect now.
Postato : 11/10/2022 1:03 pm
Super,
Happy Printing,
Joan
Postato : 11/10/2022 10:44 pm
