Partial nozzle clog?
lilnatedawr
(@lilnatedawr)
Before I go about removing the extruder set up,  want to just get some thoughts.
Recently got a Mk3s factory assembled, but when removing the filament, I am getting very long stringing:
https://imgur.com/a/9NqyzdX
This is occurring on both ends when removing filament. (the nozzle side as well as extruder side).
ran some retraction test stls using prusaslicer default settings, and there was some little very fine stringing. but was not consistent, and was sporadic. overall the print was good, other than the wisps.
I have only had boweden setups before (e3 pro), and this was usually an indicator of a bad bowden setup...is this the case with this ?
Dieses Thema wurde geändert Vor 6 years von lilnatedawr
Veröffentlicht : 15/04/2020 6:39 pm
RE: Partial nozzle clog?
are you using Prusa Slicer, or something else?
what filament are you using?
what are your settings?
Veröffentlicht : 15/04/2020 10:09 pm
Posted by: @lilnatedawr
[...] Recently got a Mk3s factory assembled, but when removing the filament, I am getting very long stringing:
That is perfectly fine and is unrelated to your fine stringing issues. If you draw the filament out the top, you can coax out very long strings like that. Pull it quickly and you'll get less.
Fine stringing is caused at the other end of the hotend by a variety of causes including heat and over extrusion.
Veröffentlicht : 15/04/2020 11:26 pm
lilnatedawr
(@lilnatedawr)
@joantabb
Hi Joan,
using the prusa filament, using the base settings on prusaslicer for mk3s
Veröffentlicht : 20/04/2020 6:01 pm
