Original Prusa i3 MK3s - MINTEMP Error - Wire cut during cleaning!
[Rozwiązany] Original Prusa i3 MK3s - MINTEMP Error - Wire cut during cleaning!
David Copher
(@david-copher)
Hi there,
I am a complete noob in the 3d printing world and during printing with the Prusa Mk3s the filament melted inside and I tried to clean it with a heat gun. Unfortunately, during cleaning, I cut a black wire. :/
Now I am getting MINTEMP error, how can I fix it? Attached picture for clarification.
Any suggestion is highly appreciated and thank you so very much for your help in advance.
Opublikowany : 15/11/2020 3:06 am
RE: Original Prusa i3 MK3s - MINTEMP Error - Wire cut during cleaning!
Posted by: @davidcopherofficial
Hi there,
Hello and welcome to the Prusaforum!
That looks quite battered, as if a blob had formed.
As I can see on the picture, the thermistor is defective because the wire is broken. You have to replace it in any case - it is available as a spare part from Prusa. I can't see exactly what is damaged, but maybe you have to replace the heating cartridge or the complete hotend and some extruder plastic parts. There are enough instructions for this in the net.
https://help.prusa3d.com/en/guide/how-to-replace-a-hotend-mk3s_161575
Opublikowany : 15/11/2020 3:42 am
David Copher polubić
David Copher
(@david-copher)
I was able to fix the issue by resoldering the hotend thermistor E3D. Thanks everyone.
Opublikowany : 15/11/2020 8:21 am
Alloys commonly used for electrical soldering are 60/40 Sn-Pb, which melts at 188 °C
Don't expect a typical solder repair to last near a hot end that operates well above the eutectic point of solder.  If you silver soldered it, or welded it, you're probably okay.
Opublikowany : 15/11/2020 8:55 am
If the soldered connection becomes loose, there is a risk of a short circuit which could destroy the Einsy. I would definitely replace the thermistor!
Opublikowany : 15/11/2020 2:46 pm
David Copher
(@david-copher)
@karl-herbert @tim-m30
Thank you guys for the advice, I will try to buy a new hotend thermistor E3D and replace it. 🙏👍
Opublikowany : 15/11/2020 8:02 pm
Good advice.  My first near fire was caused by a short in my bed wires.  I was lucky I was home and awake.
Opublikowany : 15/11/2020 9:25 pm
