Only with new firmware
matteosacco
(@matteosacco)
Updating to my MK3 the new firmware i'm having the tedious "filament runout error" .... but disabling it the printer run smoothly.
Now my problem is that in the middle of the print the extruder stops and doesn't feed filament. At the same layer, and with the same gcode used previously.
I attached it to this topic.
Can i come back to the previous 3.4.1 firmware without mess?
There are some problem in my gcode wich is uncompatible with the new firmware? I used ClintGloss preset for NGEN with simplify3D
Thanks
Napsal : 09/10/2018 11:46 am
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Re: Only with new firmware
Hi Matteo,
you can always downgrade to previous version, no special setup needed, simply flash the previous FW, but before you do this, try to slice the model using Slic3r PE to see if the prints fail at the same place.
I'm not aware of any changes to the FW which would affect the G-codes from different slic3rs, but trying our Slic3r PE is the easiest way to rule this out.
Assembly manuals
/ Knowledge Base
Napsal : 10/10/2018 4:50 pm
