One loud beep and a blank LCD screen
xoN
 xoN
(@xon)
Hello.
Something happened to my printer: after printing is finished, i cannot access the control menu and unload the filament from the extruder.
I pressed the reset button, and after turning on the 3D printer, one loud beep and a blank LCD screen appeared.
No reaction to pressing the control knob.
I cannot connect to the printer via Octopi (raspberry pi zero w + octoprint) or control the printer through its control panel.
What I was trying to do:
1) Reflash firmware;
2) Restore factory settings to shipping prep;
3) Disconnect everything except power cables and two cables from the LCD display;
4) All three fuses (5-5-15) are checked - they are all alive.
Current firmware version 3.5.1.
I can upload the firmware update log if necessary. But there are no error messages.
But I still get one loud beep and a blank LCD screen after confirming the Z-axis calibration function (it remains after resetting to factory settings).
These loud signals are similar to diagnostic codes. What do these signals mean?
Postato : 20/01/2019 5:45 am
xoN
 xoN
(@xon)
Re: One loud beep and a blank LCD screen
New simptome: Y and X motors trying to reach Home position but didn't stop when edge reached and trying to breach the wall. They moving very-y-y slowly.
Not sure why, maybe it appeared after i press Home button at Pronterface or controller board trying to execute the Z-axis calibration function.
Didn't notice that before.
Postato : 21/01/2019 7:14 am
thrawn86
(@thrawn86)
thats new to me as well, you'll definitely want to talk to support
Postato : 21/01/2019 5:29 pm
xoN
 xoN
(@xon)
The problem was solved by completely resetting the printer data.
Thanks for the help.
Postato : 22/01/2019 6:24 am
zoltanf
(@zoltanf)
Can you write how that is done?
Postato : 22/01/2019 9:06 am
xoN
 xoN
(@xon)
"All data"
https://help.prusa3d.com/article/SYvbQ66IXF-factory-reset
Postato : 23/02/2019 8:10 am
