One loud beep and a blank LCD screen
Hello.
Something happened to my printer: after printing is finished, i cannot access the control menu and unload the filament from the extruder.
I pressed the reset button, and after turning on the 3D printer, one loud beep and a blank LCD screen appeared.
No reaction to pressing the control knob.
I cannot connect to the printer via Octopi (raspberry pi zero w + octoprint) or control the printer through its control panel.
What I was trying to do:
1) Reflash firmware;
2) Restore factory settings to shipping prep;
3) Disconnect everything except power cables and two cables from the LCD display;
4) All three fuses (5-5-15) are checked - they are all alive.
Current firmware version 3.5.1.
I can upload the firmware update log if necessary. But there are no error messages.
But I still get one loud beep and a blank LCD screen after confirming the Z-axis calibration function (it remains after resetting to factory settings).
These loud signals are similar to diagnostic codes. What do these signals mean?
Re: One loud beep and a blank LCD screen
New simptome: Y and X motors trying to reach Home position but didn't stop when edge reached and trying to breach the wall. They moving very-y-y slowly.
Not sure why, maybe it appeared after i press Home button at Pronterface or controller board trying to execute the Z-axis calibration function.
Didn't notice that before.
thats new to me as well, you'll definitely want to talk to support
The problem was solved by completely resetting the printer data.
Thanks for the help.
Can you write how that is done?
"All data"
https://help.prusa3d.com/article/SYvbQ66IXF-factory-reset
