OctoPi and LA issue fixed?
justin.wunderlich
(@justin-wunderlich)
Hey guys
just wanted to ask you very quick, if the stuttering issue when printing over OctoPi with Linear Advance on got fixed?
Curious because I want to print over Octoprint and USB.
Opublikowany : 10/05/2018 6:58 pm
TTGG
 TTGG
(@ttgg)
Re: OctoPi and LA issue fixed?
I have been using 3.2 RC2 for a while now w/ Octoprint via USB and I have LA enabled. All looks good and LA does make a difference.
Opublikowany : 10/05/2018 7:56 pm
justin.wunderlich
Very nice!
So no stuttering issue? How much have you been printing? 🙂
Opublikowany : 10/05/2018 8:01 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Ditto. Running 3.2.0 alpha with LA via Octoprint and no problems
Peter
Opublikowany : 10/05/2018 8:07 pm
justin.wunderlich
Great thanks guys!
Looks like I finally can enjoy the ease of Octoprint again 🙂
Opublikowany : 10/05/2018 8:43 pm
eric.d14
(@eric-d14)
I was under the impression that problems were more prevalent using a pi Zero W due to the weaker processor. Has it similarly improved with the latest firmware or is it still recommended to spring for a more robust pi 3+?
Is USB still the way to go instead of the GPIO connection? (I seem to recall problems with that as well)
Opublikowany : 11/05/2018 12:13 am
PJR
 PJR
(@pjr)
I believe the Pi Zero attached directly to the Einsy still uses serial comms, so it really is of no benefit.
And I would never use a Pi Zero and expect it to work as reliably as a faster 4 core version.
Peter
Opublikowany : 11/05/2018 1:16 pm
Nospoon
(@nospoon)
I am using Pi Zero W attached directly to Einsy and it works beautifully, no problems so far.
Opublikowany : 12/05/2018 8:19 pm
Protoncek
(@protoncek)
I played with my Zero over the weekend, too. As far as printing goes it really prints without any problems, but overall it's...well, no so good:
- first of all it takes ages to acces it at power-up.
- it can happen that if i try to connect with phone it won't connect, i've had occasions where whole system crashed and rebooted.
- as camera goes, having resolution more than 640x480 results more in random slidewhos rather than video.
I have updated raspberry and octoprint to latest.
I wonder ---i have old Rpi2 at home - will be any better/faster? Or should i buy latest Pi in order to work flawlessly?
Opublikowany : 14/05/2018 10:39 am
ClassicGOD
(@classicgod)
RPi2 will be faster than Zero but has no built in Wi-Fi so you will need an adapter. I highly recommend the newest RPi 3 B+, it's much faster than my Pi 2 and the build-in Wi-Fi is better than on standard Pi 3.
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Opublikowany : 14/05/2018 12:42 pm
Protoncek
(@protoncek)
well, i have switch 2 metres from my printer, so i'd rather connect Rpi with cable, but zero doesn't have this option...
OK, i will try Pi2 first and see, thanks..
BTW...will SD card from zero work in rpi?
Opublikowany : 14/05/2018 12:48 pm
