Nozzle too low for a good first layer calibration
Why my nozzle is too low to get a good first layer calibration? Right now is at -1.765 for the steel sheet.
I set the PINDA as instructed with the tie wrap i even lowered a little more but same result. Is this normal or maybe some bad assembly?
Thanks
RE: Nozzle too low for a good first layer calibration
Thanks
you should be able to get a good layer, why is -1.675 a problem?
If you want the number to be smaller,
reset your live Z to 0.0 mm for safety, then raise your pinda 1 thread, that should equate to 1mm, then reset your live Z (If you don't reset your live Z to 0.0mm you may damage your build plate. )
are you using 7x7 mesh bed levelling (LCD Choice) ?
have you tried 'Life Adjust Z My Way' by Jeff Jordan?
there are test files in a zip file at the bottom of the first post.
Is your build plate really clean, no fingerprints no contamination?
have you tried 70C on the bed for PLA?
@joantabb
Because in the first layer guide state a common range is -0.400 to -1.500 I though -1.765 was too low but i will try your suggestions. Thank You Joan!
the window of acceptable live Z values for Your printer is unique to you.
and it is quite a narrow range.
this is a print off my printer for example.
the values are unique to my printer, but the differences indicate the changes in quality over a small live Z range.
If you're close to or above -2, I would reposition the PINDA higher.
The Super PINDA should have about 1.5 mm distance between nozzle and SPINDA, so that you’re around -1 when your Live Z is correct. (For the old PINDA, it was 0.8mm).
Instructions are in Step 16 of https://help.prusa3d.com/en/guide/how-to-replace-superpinda-mini-mini_179912 (Mini) or
https://help.prusa3d.com/en/guide/how-to-replace-superpinda-mk3s-mk3s_179920 (Mk3S)
I put this little helper on Prusaprinters.org to help position the SPINDA: https://www.prusaprinters.org/prints/57192-spinda-height-adjustment-tool-mounts-into-3030-ext . Works better than zip ties or credit cards, which have less well-defined heights.
For an illustration of relationship of distance of PINDA to nozzle and sheet, see
