Nozzle leaking filament
Tonksy
(@tonksy)
Nozzle leaking filament as soon as I pre heat nozzle,  it's a constant tiny flow.  Any help please?
Thank you
Opublikowany : 21/05/2019 2:15 pm
Vojtěch
(@vojtech)
RE: Nozzle leaking filament
Some small leakage is normal if you let the printer idle hot. Excessive leakage can be a symptom of a wet filament that has absorbed too much moisture from the air. (Typical for PVA, Nylon, ABS, PETG, not common in PLA).
This post was modified 7 years temu by Vojtěch
Opublikowany : 21/05/2019 2:57 pm
Tonksy
(@tonksy)
Thank you for your reply, just purchased a food dehydrator to convert into a filament dryer, will give it a go......
Opublikowany : 21/05/2019 3:09 pm
gnat
 gnat
(@gnat)
I also notice that this varies from filament to filament even within the same type (e.g. PLA) too. I expect it has to do with the ideal melting point for the given filament.
I have some PLAs that will do this too me bad enough that I need to get it printing as soon as it's loaded. Others can sit idle at printing temp for an hour and nothing dribbles.
MMU tips and troubleshooting
Opublikowany : 21/05/2019 3:18 pm
