Nozzle impossible to unscrew?
Sixela963
(@sixela963)
Hello everyone. About a month ago, I assembled a Prusa MK3 kit and I have been extremely happy with it. Currently, I am attempting to switch to a 0.25 nozzle for high precision prints (such as miniatures). However, while trying to follow the instructions to change the nozzle on the prusa help site, I get stuck at step 5, unscrewing the nozzle. Now, I will say that I do not have a spanner for the nozzle. I am holding the heating block with an adjustable wrench, and I am trying to unscrew the nozzle with the supplied pliers. It simply will not come off. I fear that if I use more force that I am already using I may damage the nozzle - I believe I may have made a few scratches already.
Are the pliers supposed to be enough to unscrew the stock nozzle? If not the instructions should reflect that better. If so, what could I be doing wrong?
Thank you for your help.
Veröffentlicht : 19/02/2023 7:05 am
Hello
(@hello)
RE: Nozzle impossible to unscrew?
Make sure nozzle heated above highest temperature fillament used
Veröffentlicht : 19/02/2023 7:44 am
Sixela963
(@sixela963)
Posted by: @hello
Yes, I used the built-in function to heat the nozzle hot end to 280°C.
Veröffentlicht : 19/02/2023 7:52 am
Hello
(@hello)
Contact prusa through live chat they can step by step on how to do it and any problem they will help you
Veröffentlicht : 19/02/2023 7:55 am
After spending a $1000+ on a printer, you really don't want to skim on the tools. Buy some proper sized wrenches, and/or print one of the 3Nm torque wrenches here: https://www.printables.com/model/24539-torque-wrench-handles-from-10nm-up-to-30nm
And of course, @hello's suggestion to contact Prusa support makes sense to find someone who can talk you through it.
Veröffentlicht : 19/02/2023 11:37 am
JimB
 JimB
(@jimb)
also make sure you are not trying to tighten it.
Veröffentlicht : 19/02/2023 3:18 pm
Crab
 Crab
(@crab)
yes.. +1.. I was inadvertantly tightening it when I did mine.. .. (lefty loosey) .. and use a socket for the nozzle, not an adjustable..
Posted by: @jimb
Veröffentlicht : 19/02/2023 4:12 pm
