Noise from the power supply
JosefLoukota
(@josefloukota)
Since the build, the power supply on my printer has been making a loud noise. The noise starts as soon as the printer is turned on and can be heard all the way through the run time. I am concerned about a faulty power supply, damage to the printer, or burnout. Support has told me that this sound is normal. Please does anyone have the same experience?
I am attaching a video which shows that both fans are not moving and the sound is indeed coming from the power supply.
Napsal : 10/08/2022 12:42 pm
JosefLoukota
(@josefloukota)
RE: Noise from the power supply
Napsal : 10/08/2022 12:50 pm
JimB
 JimB
(@jimb)
I hadn't noticed it before, but mine appears to make the same sound.  It is not at all loud: easily drowned out by.... anything
Napsal : 10/08/2022 3:43 pm
Robin
(@robin-2)
mine sounds identical.  Please post if you have problems with it.
Napsal : 06/09/2022 5:34 pm
