Newest firmware update fails at the last step in Prusa Slicer 2.2 - Reboot
Dan Rogers
(@dan-rogers)
I flashed my Mk3S with the latest firmware (timeline December 2020) - and it flashes (write), then the verify phase (read) - but it doesn't wait long enough for the reboot after the verify phase - so Prusa slicer 2.2 reports that the flash operation failed due to lack of USB(com4) connectivity.
After trying three times, same result - I checked the firmware version on the printer display - and it appears as though the new firmware is in place.  Not sure how to verify that I'm getting the artifact reduction improvements I expected - tried a few pre-update GCODES and every single defect is still present (even blobs at knife edges).    Is the new firmware there, as is being reported - or do I need to wait for a Prusa Slicer 2.2. update to wait for the reboot to finish the job.
Opublikowany : 01/12/2020 5:09 pm
RE: Newest firmware update fails at the last step in Prusa Slicer 2.2 - Reboot
Posted by: @dan-rogers
I would perform a factory reset, use a different USB cable and try to reflash the firmware. Normally no error message should appear. Best is to use the latest version of the PS. But after the factory reset you have to recalibrate because all the presets will be erased from the eeprom.
https://help.prusa3d.com/en/article/firmware-updating-mk3s-mk3_2227
Opublikowany : 01/12/2020 6:23 pm
Dan Rogers
(@dan-rogers)
@karl-herbert
Thanks.  I think I'm using the latest slicer already, and thank you for the link.   It isn't clear how to factory reset - so I'm hoping that is an option on the screen on the printer.
Opublikowany : 01/12/2020 6:29 pm
