Moving the PSU
Blackadder
(@blackadder)
Moving the PSU
Hi all, I am planning on moving my PSU from inside my Lack Table enclosure and wanted to know if Prusa (or any other supplier) sells a wiring extension loom. Or has anyone else gone through this process and can let me know what needs doing.. Thanks
Veröffentlicht : 12/06/2022 12:36 am
Blackadder
(@blackadder)
RE: Moving the PSU
Sorry.. it's a Prusa MK3S
Veröffentlicht : 12/06/2022 12:37 am
Mitglied
RE: Moving the PSU
You need wire extensions.  It is fairly easy.
Veröffentlicht : 12/06/2022 1:07 am
richnormand
(@richnormand)
RE: Moving the PSU
Looking at my printer (MK3S) with the spool on top I was wondering if the printer imparts more flexing rigidity to the frame when bolted in place?
If you look at a kg filament spool sitting on top and back and the possible induced resonance with the bed moving in the back-front direction it might do some flexing of the frame????
I'll loosen the PSU on mine and see if there is an effect. If so a simple L type rail bolted at the same place might help when the PSU is removed.
REPAIR, RENEW, REUSE, RECYCLE, REBUILD, REDUCE, RECOVER, REPURPOSE, RESTORE
Veröffentlicht : 12/06/2022 7:44 pm
