[Solved] Motor pulley grub screw check
kennd
(@kennd)
For kit builders.
After 9 months, during Y-axis maintenance, I checked the motor pulley and discovered that the grub screws were just barely holding on and I had to re-tighten them. It was only a matter of time before they let loose and caused a problem. I know they were tight at time of assembly.
I have now included a scheduled "motor pulley" grub screw check over and above any other maintenance.
Quality is the Journey, not the Destination. My limited prints->
Napsal : 17/03/2020 11:58 pm
rmm200
(@rmm200)
RE: Motor pulley grub screw check
Add words to describe tightening.
You have to loosen both, align one with the flat, fully tighten that one - then tighten the other.
Done any other way - they will come lose again.
Napsal : 18/03/2020 1:38 am
kennd
(@kennd)
My bad!
I should have prefaced my post with:
"This is not a how-to post but is for awareness only. It documents what I found and what I am doing to prevent an issue in the future."
Napsal : 18/03/2020 1:57 am
