MK3S stuck in recovering print
souki
(@souki)
I was trying to start print yesterday on MK3S but it showed the "new firmware available". I have killed the printer with power switch and it made loud beep (power panic?). I have updated firmware to 3.7.2 today with no problems but now it shows "recovering print", then "heating" but nothing is happening. There is no print menu and if I try to start different print it is still stuck in "heating" without temperature changing.
What can I try to fix this?
Thank you!
Publié : 18/07/2019 7:22 pm
RE: MK3S stuck in recovering print
Hi Soukup,
Never had this problem myself...   have you tried pressing the X button, under the LCD knob, whilst the printer is turned on, to reset the firmware?
if that fails, you could try a factory reset, but you would have to do live Z again, and if you have used it bed level correction too...
Publié : 18/07/2019 7:57 pm
souki
(@souki)
I have tried the "X" reset with no luck. I will try factory reset, thank you!
Publié : 18/07/2019 8:08 pm
try factory reset without clearing data  first, if that doesn't work, try again including clearing data.
best wishes, Joan
Publié : 18/07/2019 8:38 pm
carlos.p10
(@carlos-p10)
Any luck from anyone having this problem? What does PRUSA say?
Publié : 30/07/2019 6:08 pm
souki
(@souki)
Sorry, forgot to update.
I have used factory reset, did calibration again and everything works!
Thanks for your help @joantabb!
Publié : 30/07/2019 6:10 pm
Fisk Family
(@fisk-family)
Hi, I am having this problem a lot with my MK3S. I switch it on, it says "Recovering print", then goes into "Heating..." but it never finishes because it is aiming for a temp of zero. Usually I'm able to clear it by getting the printer to do something else, such as selecting "Preheat" or removing the filament. But if I select to "Print from CD", it won't start. this evening none of the methods to clear it seem to have worked, no matter how many times I reset or try to "distract" the printer into doing something else. I would rather not have to recalibrate each time to clear this. Are then any updates on this problem? I have firmware 3.8.1-2869 - haven't yet checked if this is the latest. Thanks
Publié : 30/04/2020 8:05 pm
