MK3S+ strange noises
kingof7eleven
(@kingof7eleven)
Hello, I have several MK3S+ and I am not completely inexperienced. All work well only one makes loud noises (see video). Exclusively with diagonal movement.
The bed is leveled perfectly, the Z height is correct and nothing is loose. The print quality is also not negatively affected.
Does anyone know where the noise can come from?
Sascha
Respondido : 13/06/2023 2:34 am
Hello
(@hello)
RE: MK3S+ strange noises
caRnt play video but it could be bearings try lube theme
Respondido : 14/06/2023 8:48 am
kingof7eleven
(@kingof7eleven)
bearings are ok and lubed. Can you try to open the video in a new tab? That works or me.
Respondido : 14/06/2023 12:12 pm
Hello
(@hello)
Done that and reformated it looks like it's corrupt could you try upload it but in a zip file
Respondido : 14/06/2023 7:46 pm
kingof7eleven
(@kingof7eleven)
Please try this link for the Video:  http://bcd24.de/test/noise.mp4
Respondido : 17/06/2023 6:59 pm
Hello
(@hello)
That sort of sounds like the motor where is the noise coming from
Respondido : 17/06/2023 7:21 pm
Hello
(@hello)
Is it coming from x y or z axis
Respondido : 17/06/2023 7:22 pm
Hello
(@hello)
I caRnt play the video now it did once. Put the printer into stealth mode that may fix it
Respondido : 17/06/2023 7:24 pm
vhubbard
(@vhubbard)
My MK3s+ had 30 days of printing and it started to get a little noiser.   I found the Y axis rod mount screws were all snug, but 1/2 to 3/4 turn to tight.   Checked and tightened the 16 screws related to the Y axis rods and it quieted back down
Respondido : 08/07/2023 3:13 am
Robin_13
(@robin_13)
My printer has started to sound this way as well.  All bearings are lubricated and  I know it is the Y axis that makes the noise.  Will have to check the rods.  Printer was quiet after assembly in March.
Respondido : 14/07/2023 7:32 am
