Mk3S software 3.7.1 SPI FLASH problem with loading SD and ? value axis
toma.l17
(@toma-l17)
Hello,
After rebuilding MK3 to MK3S and loading new software SD card cannot be loaded and also the values of axes are ?.
Can anyone help me?
Thank you
This topic was modified 7 years temu 2 times by toma.l17
Opublikowany : 24/06/2019 1:47 pm
n9jr
 n9jr
(@n9jr)
RE: Mk3S software 3.7.1 SPI FLASH problem with loading SD and ? value axis
None of your screen shots are viewable.  But after the MK3S upgrade my hot end fan didn't turn on.  You might consider a factory reset, and perform a calibration and see if SD functionality returns.  It helped me. Vintagepc who tipped me off said there were a number of quirks that needed a reset.
This post was modified 7 years temu by n9jr
Opublikowany : 25/06/2019 12:04 am
1 ludzie polubili
toma.l17
(@toma-l17)
Opublikowany : 25/06/2019 11:05 am
toma.l17
(@toma-l17)
I tried factory reset and calibration but result is same. Reupload pictures.
Opublikowany : 25/06/2019 11:11 am
n9jr
 n9jr
(@n9jr)
Not reading the axis is problematic.  As for the SD card have you tried another to rule out the SD card itself?  Did your XYZ calibration complete successfully?
Opublikowany : 25/06/2019 11:16 am
toma.l17
(@toma-l17)
I tried another card and also I tried connect display to the mk2s and everything works. Yes complete calibration was done without problem.
Opublikowany : 25/06/2019 11:32 am
ThaliaFP
(@thaliafp)
I encountered the same problem, just without the Z-Axis bug.
Received a new LCD today but it didn't help either. I don't know what to do 🙁
My designs in Thingiverse
Opublikowany : 29/06/2019 8:21 am
ThaliaFP
(@thaliafp)
Posted by: ThaliaFP
I just contacted the support and they said that some of the Einsy boards didn't survive the last frimware update. So I will receive a new one and have to send the old one back. Very good customer service ❤️
Opublikowany : 29/06/2019 9:03 am
toma.l17
(@toma-l17)
After replacing einsy board that has been tested for MK3S, is problem partly solved.
Now, when I upload software trough slicer everything works.
After upload trough arduino IDE, SD card works, but axis values are ? still.
I use for measuring temperature on nozzle pt100 with amplifier.
That's why I have to upload the program through Arduino IDe.
For now I will be satisfied that I will not know the axis values, but I can print.
So if you have the same problem contact support and they will replace your electronics.
This post was modified 7 years temu 2 times by toma.l17
Opublikowany : 03/07/2019 1:32 pm
