Mk3S software 3.7.1 SPI FLASH problem with loading SD and ? value axis
toma.l17
(@toma-l17)
Hello,
After rebuilding MK3 to MK3S and loading new software SD card cannot be loaded and also the values of axes are ?.
Can anyone help me?
Thank you
Questa discussione è stata modificata 7 years fa 2 tempo da toma.l17
Postato : 24/06/2019 1:47 pm
n9jr
 n9jr
(@n9jr)
RE: Mk3S software 3.7.1 SPI FLASH problem with loading SD and ? value axis
None of your screen shots are viewable.  But after the MK3S upgrade my hot end fan didn't turn on.  You might consider a factory reset, and perform a calibration and see if SD functionality returns.  It helped me. Vintagepc who tipped me off said there were a number of quirks that needed a reset.
Questo post è stato modificato 7 years fa da n9jr
Postato : 25/06/2019 12:04 am
1 persone hanno apprezzato
toma.l17
(@toma-l17)
Postato : 25/06/2019 11:05 am
toma.l17
(@toma-l17)
I tried factory reset and calibration but result is same. Reupload pictures.
Postato : 25/06/2019 11:11 am
n9jr
 n9jr
(@n9jr)
Not reading the axis is problematic.  As for the SD card have you tried another to rule out the SD card itself?  Did your XYZ calibration complete successfully?
Postato : 25/06/2019 11:16 am
toma.l17
(@toma-l17)
I tried another card and also I tried connect display to the mk2s and everything works. Yes complete calibration was done without problem.
Postato : 25/06/2019 11:32 am
ThaliaFP
(@thaliafp)
I encountered the same problem, just without the Z-Axis bug.
Received a new LCD today but it didn't help either. I don't know what to do 🙁
My designs in Thingiverse
Postato : 29/06/2019 8:21 am
ThaliaFP
(@thaliafp)
Posted by: ThaliaFP
I just contacted the support and they said that some of the Einsy boards didn't survive the last frimware update. So I will receive a new one and have to send the old one back. Very good customer service ❤️
Postato : 29/06/2019 9:03 am
toma.l17
(@toma-l17)
After replacing einsy board that has been tested for MK3S, is problem partly solved.
Now, when I upload software trough slicer everything works.
After upload trough arduino IDE, SD card works, but axis values are ? still.
I use for measuring temperature on nozzle pt100 with amplifier.
That's why I have to upload the program through Arduino IDe.
For now I will be satisfied that I will not know the axis values, but I can print.
So if you have the same problem contact support and they will replace your electronics.
Questo post è stato modificato 7 years fa 2 tempo da toma.l17
Postato : 03/07/2019 1:32 pm
